Aftermarket ECU wiring solution
Traders Section
Gunni
Post Mon May 27, 2013 8:15 pm
I can do peoples ecu wiring for them for 225pounds + return shipping.
This will include testing ALL used functions so that the engine will start on the first go and calibrating wideband sensors if needed. Doesn´t matter what engine is it as longs it´s not a full blown S62 or similar (S50´s and M60´s are in). Doesn´t matter which ecu it is either.
This would include adding any required injector/ignition/cam sensor/tps/auxiliary sensor/wideband/comms wiring required.
Below is a modified M30 loom to run with VEMS.
Mods included adding injector wiring, wasted spark wiring, TPS wiring extension for relocated throttle body, wideband wiring, air temp sensor wiring and then calibration of the sensors in the ecu.
Generally about 1week turnaround, shipped back with tracking number.
For this to work I will need the following
Loom
ECU
As many OEM sensors as possible(crank sensors not needed unless requested), Any additional knobs, switches or devices that need wiring in as well.
Gunni
@ 2012 VEMS group buy !!
