Hi guys,
Im having an issue with starting my car after returning from holiday (M20b25 pre facelift). Im basically getting no reaction from the engine when turning the key, i hear some buzzing but the actual engine doesnt turn. It however does start if i get someone to give it a push and i wack it in gear two and release the clutch. Is this the starter motor gone? If so how easy are they to change?
thanks
not starting with key, only jump
lyricalnut02
325i Sport Tech 1 - R.I.P
E30 addict.
E30 addict.
Sounds like it could be the starter motor on the way out or sticking - try rocking the car back and forth in gear then try the starter.
It could be the solenoid not working properly - check all connections to the starter motor are tight.
lyricalnut02
speedtouch, where is the starter located on the engine? any pics to guide me?
E30 addict.
E30 addict.
Down on the bellhousing on the inlet side, about level with the alternator in this photo:
lyricalnut02
can i reach it without removing any other items?
E30 addict.
E30 addict.
lyricalnut02
cheers pal
E30 addict.
E30 addict.
