Headlamps not working
jimf
Post Mon May 13, 2013 6:55 pm
both My headlamps have decided to not work and instead when I pull the knob all my indicatiors come on steady.
I admit that I had taken the lamp out to change the left to right direction and it all worked when i put it back, but after a short drive this now happens.
I suspect the bulb holder is a little tempramental, would this go along with the symtoms?
Post Mon May 13, 2013 7:25 pm
Check out the main earthing point at the front of the LH inner wing. Take it apart, clean, and bolt back together.
jimf
Post Tue May 14, 2013 11:55 am
Absolutely spot on Brian, the nut was loose. Why it decided to show up on the MOT retest was just bad bloody luck. Anyway, passed now. Many thanks as always.
