Floor wiring pics
polsta
Has anyone got any nice pics of floor,sills,any other areas , if pos pre dash install and also how the loom should look when clipped to underside of the dash before it goes in ? , wiring all clipped in like factory fresh ? Before carpets etc, that I can use for reference , got all new fittings comming this week and want to get it right ! Someone must have some ,
- E30 Zone Meets/Events Team
Should have asked yesterday, as I only removed ALL my loom about lunch time.
polsta
Ahh man , I got rough jist of it all but just need some pics of how it should look properly done, and the loom bit that goes across the floor pan pass side and wiring around the tunnel/under console and bits like that ,gone to the effort if new fittings so want it done properly, hoping after tomorrow il be ready to fit the dash
Loom fits and goes along the passenger side sill to the rear seat base.
Then it feeds into the boot for the rear lights, and also across the rear passengerside to the driverside, the back along the driverside sill to towards the front speaker well.
Half way through, it veers of towards the transmission tunnel to the Handbrake switch, and reverse light.
And then carries on over the transmission tunnel, that's from memory.
polsta
Yeah I've got all the rear/sill looms in place , its how the towards tunnel loom is fitted and clipped exactly and how the behind dash areas should look before dash goes in , and I have no idea how the loom that clips to bottom of the dash should be like ? Someone must have pics ? , the dash swap/removal guides do not show that, as they just say re fitting it all is same as removal, which was a long time ago now
If anyone's got pics or can give good explanations, il take lots if pics so a wiki article can be written for refitting of it all, which with all the new bits will make for a good article
