318 is engine rattle!!!
WEEMANDANBRITTON
Post Thu May 09, 2013 2:43 pm
at around 3000 - 4500 revs i have a rattle!!!
i have changed the cam chain tensioner, done an engine flush and put fresh oil in, at the same time checked the dredded bolts in the sump and it was all fine!!
i took both aux belts off and the rattle went so i put the belts on individualy and the rattle came back when i put the p/s belt on so i thought it was the power steering pump but then i put the other belt on hoping there would be no rattle and it was there again!!
im thinking it may be somthing with the bottom pulley or bottom end?
any advice would be deeply appreceated!!
