Exhaust
Aziz
Sun May 05, 2013 3:28 pm
Hi
Can anyone put up a picture for the exhaust mounting points on 325i
At the moment exhaust is only secured at back box there must be more
Is there differences between chromie and face lift
I'm going to a exhaust made and want it installed correctly
maggspower
Turbo Farmer Tractor Driver
Sun May 05, 2013 3:39 pm
There should be 2 hanger straps on the backbox, a rubber on the rear beam, and the gearbox mount.
The mounting points are the same pre and post facelift.
ranxerox
Sun May 05, 2013 3:49 pm
delete
Aziz
Sun May 05, 2013 4:34 pm
Thanks for quick replys
I believe the gearbox mounting point is a bracket (need to find one in the garage)
rubber mounts for the rest.
Imran
