Vent removal from dash?
M6luvva
Post Sat May 04, 2013 12:37 pm
Does anyone know how to remove the slider vents from the housing in the dashboard?
http://img191.imageshack.us/img191/5903/imagejycx.jpg
Thanks, Chris.
polsta
Post Sat May 04, 2013 12:40 pm
They just clip out mate, I'm not sure if there's a specific way but I removed some from and old dash to be binned , thin flat screwdriver prized them out they just pop out , but wait for confirmation if there is a proper way to do it incase you damage the dash
M6luvva
Post Sat May 04, 2013 1:02 pm
Thanks Polsta, and just to be quite clear, I don't want to remove the entire housing/assembly, just the two vents/grilles. There is some resistance when trying to pry out with a screwdriver. I know in my Merc 190e, a pair of pliers wrapped in towel to avoid leaving marks and a tug towards you does the trick. Anyone else attempted this?
polsta
Post Sat May 04, 2013 1:23 pm
I see ,it's not hard to pop the whole unit out, its just 2 little plastic clips at each end i think,just carefully try to pop it out being careful not to mark the dash, might be better than pulling the vents out incase you snap them
