Driving along tonight about 75 and suddenly got a loud rumbling noise which at first I thought was the road surface.
It turns out when the revs go over 2500 there is a loud "rumbling" and some vibration. Also when pulling away there is a similar noise.
My first thought was the bottom end had gone, although the fact it idles OK without noise and cruises along OK i have dismissed this.
What does a "dual mass" flywheel sound like when it fails ? as this is my diagnosis at the moment. Whats the danger in continuing to drive it "carefully" if it is this ?
Any pointers appreciated !!
318ti Bad Vibrations
gareth
Alright Kev
wheel speed related? Rear driveshaft CV failure? dare I say it... Could it even be a loose / damaged wheel? 75mph seems to be where wheel issues resonate
320Touring
Hi Kev
when DMF's fail, its usually accompanied by a lack of being able to get a gear- If the car still selects all gears ok, then i'd rule it out
the rumble sounds like its more likely to be rear end of the drivetrain, as per Gareths suggestion.
Ajsingh
Prop bushings could be worn possibly?
E30 Crazy!
