LHD Air Con Question /Removal?
scott180gtb
Post Thu May 02, 2013 12:35 pm
Can anyone confirm that the air con unit that sits under the dash is not LHD specific.
I want to remove the unit to sell but just want to be sure that a UK RHD box will go back in.
Also what the best way to remove the unit. What about draining the gas?
Cars
2007 VW Caravelle 2.5 TDI 250 bhp 550 NM
1989 325i Sport Gone :(
2003 E46 320d Touring
1998 E36 M3 EVO Track Toy
1996 E36 328i Sport welder-up project
Post Thu May 02, 2013 1:31 pm
ETK gives the same part numbers for LH drive cars as it does for RH drive versions, so yes.
So easy to check!
By law, the gas has to be recovered to a container, but most will have leaked by accident through a loose joint in the system (in a well ventilated area.)
Post Thu May 02, 2013 6:02 pm
Scott will inhale the refrigerant himself, he is a hardcore diseasel fitter innit :D
scott180gtb
Post Sun May 05, 2013 4:38 pm
Dan we are due a six month service on my machine next week.
We will be removing x3 DPF filters from the exhaust and going to normal silencers.
V8 Single turbo Diesel Power. :D
Might see if I can weigh in the filters :D
Cars
