could this be the damper
optima
the drivers side of my car is sitting alot lower than the other. is this likly to be the shock or bushes. the bushes look fine and when i bounce the car it stop dead but the springs are very stiff. and my bloody heater matix blew today so im not having a good day
gcorky
- Boost Junkie
broken spring
Simon
Sounds like a broken spring, the shock absorbers are there to damp the bumps, the springs actually hold the car up, broken springs on the E30 are quite common.
kam-325i
More common than on Mondeo's ?Simon wrote:broken springs on the E30 are quite common.
Simon
Don't swear at me!!kam-325i wrote:More common than on Mondeo's ?Simon wrote:broken springs on the E30 are quite common.
I've never been a mondeo fan so couldn't say!
I can say that the E30 is quite old now, I have had 2 E30's with broken springs, and I have read numerous posts on here with regarding broken springs.
kam-325i
I know of 7, yes 7, 6 year old mundane'os that had suffered from broken front springs.......
optima
sorry i should have said i have just lowered the car. with new springs. was leaning before the change and it is on the rear.
gcorky
- Boost Junkie
same size wheels ,tyres ,check spring seats on arm and chassis.
optima
ha ha
i got it its the rear subframe bushes every time i jacked it up it would go back so i couldnt see it just lowered it onto blocks and it popped out lovely now i gotta change them
see u in a week
TOURINGDADDY
optima
where are the top mounts
kam-325i
they are where the top of the shocks mount/bolted to chasis.
optima
i just looked they do look different this would effect the ride hight will it cus its the shock not the spring mount
kam-325i
The ride height is governed by two things, The springs and rear subframe bushes. The shocks do not affect ride height.
A car will ride/drive at the same height without shocks fitted, but it will bounce about all over the place without the dampening effect of the shocks.
TOURINGDADDY
optima
well the shock top has seem to have gone i will change it tomoro and see if it works if not i will change the subframe bushes but the top mount has gone strange
Simon
Dampers hardly effect the ride height of the car, the reason the top mount can cause different ride height is when the shock absorber goes through the top mount, and cause it to sag slightly.TOURINGDADDY wrote:so how do u explain the passanger rear of my tourer been lower than the other side and when i looked into it it was a dead top mount causing this problem. shox will keep a car level to a certain extent
