Removing stone chip from front valance
Topblag
Wed Apr 24, 2013 3:24 pm
I'm replacing the valance on my prefacelift cabby. I'm going back to metal before new paint and wondered the best way to remove the stone chip underneath the white paint ?
Heat gun and scraper ?
Electric or hand sanding ?
Never tackled this job before, advice welcomed.
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
Rtaylor2208
Wed Apr 24, 2013 5:29 pm
One of those wire wheels that goes on a drill will work but you need to be fairly gentle.
Topblag
Wed Apr 24, 2013 5:52 pm
Will that not gum up the wire wheel ?
Wed Apr 24, 2013 6:47 pm
Heat gun doesn't work on the OE stuff. Rotary wire brush in an angle grinder shifts it OK.
Why would you need to be gentle, if you're going back to bare metal?
Topblag
Wed Apr 24, 2013 7:18 pm
Thanks, will give it a shot.
bdx
Wed Apr 24, 2013 10:01 pm
Use a flap wheel and angle grinder
Wed Apr 24, 2013 11:06 pm
Flap wheel does need to be used with care. Those things can remove a surprising amount of metal in a short time.
