Central locking not working?
Salwayne
Post Tue Apr 23, 2013 2:19 pm
I was told by bmw that my e30 did not have central locking but since then I have noticed actuators on the boot lock and on the petrol cap... But none lock I checked fuse 27 which I found on the wiki to be for central locking and that's fine, was wondering what my next step was?
Grrrmachine
E30 Zone Wiki / Team Member
Post Tue Apr 23, 2013 3:35 pm
Post Tue Apr 23, 2013 8:34 pm
In your case, the first thing to do would be to remove the driver's speaker panel in the footwell, the speaker, the plastic plate below it, and to check if you actually have a locking ECU fitted.
Salwayne
Post Tue Apr 23, 2013 8:37 pm
Yeah it's there it's the 'temp fuse' but I need to get hold of some low temp solder but I touched it together and the whole system worked
Post Tue Apr 23, 2013 8:40 pm
There should be enough existing solder there to reset it. Everything is already tinned, so no flux is needed - just a hot iron to reflow the solder, and a steady hand to hold the spring in while the solder sets.
Salwayne
Post Tue Apr 23, 2013 8:55 pm
I tryed that but it didn't stick
Post Tue Apr 23, 2013 9:34 pm
You probably let things move before the solder had set.
Salwayne
Post Tue Apr 23, 2013 9:36 pm
I had it clamped up heated it up until the solder melted and went back out to the car to swop speakers over when I came back it was cold to the touch let the clamp off it stayed there momentarily and pinged off
Salwayne
Post Mon Apr 29, 2013 7:58 am
Its held this time, i stripped a large section of my solder real, i think the flux had gone bad in the end seeing as its an old real, appreciate all the help! Was really pleased that all the locks function properly!
