I've got a 318 with a M20B25 conversion which was running fine until I put it back on the road again after a year or so off the road. Ever since I started driving it again I've had drivetrain noise mostly from the rear & some vibration at speed. I changed the guibo, centre bearing & centre mount on the prop & got it rebalanced but still no change. I swapped the diff a while back as well as that was my first thought and that made no difference either
The only thing I've noticed recently is some bearing noise from the gearbox on idle. All the conversion parts; engine, box, driveshafts, prop etc are from a 1987 tech1 sport so not surprised if they're getting a bit long in the tooth.
Any help would be appreciated as this is ruining the driving experience a bit.
