Does a e36 325i gear box fit in a e30 325i
shane281189
Does a e36 325i gear box fit in a e30 325i ?
jmc330i
Yes, but at a funny angle which means custom/modded gearbox crossmember and linkage and you will need a diff change to one with the appropriate ratio for the E30 gearbox. Not sure which propshaft you would need.
Quite a bit of work and no real gains unless youre fitting it complete with E36 325i engine.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
