Any body know which bulb I need to buy to replace a blown bulb in an automatic gear shifter? (ie the bulb that illuminates PRND etc)
I've searched through the wiki and can't seem to find any info for this.
Automatic shifter bulb
bigwinn
from memory its the standard dashboard bulb- cant remember code but use the halfords look up guide in store-
or pop the cover off with the brush on and take it out to take with you
Bronzit gone- she lives on
'89 325i auto touring: Malachite Green
Now, I'm no gynecologist, but I know a tw4t when I see one...
ThomasBellamy
Thanks, I think I found what I need now on the Halfords website.
darkchild
Is the bulb definitely blown? Failure of light here is normally due to the wire to the bulb holder being broken.
ThomasBellamy
I'm not sure, I haven't had a look under the cover yet. Where does the wire normally break?
darkchild
Remove the brush cover (it just unclips) and you'll soon see if the wire is broken. The wire tends to weaken with age due to repetitive movement from Park to Drive.
Wire breaks where it flexes the most as you move the selector. All should be obvious when you remove the brush plate.
Bulb is the same 1.2W capless lamp that's used for most of the rest of the dash illumination and warning lamps. It's an incandesant lamp and will fail eventually, so you may be lucky that it's just that.
ThomasBellamy
As darkchild suspected... popped the cover off and the wire had completely snapped off. didn't have the tools to fix properly so will have to wait for another day
darkchild
Very, very common on slushmatic E30s. Time to get busy with the soldering iron! I've had to fix mine a couple of times.ThomasBellamy wrote:As darkchild suspected... popped the cover off and the wire had completely snapped off. didn't have the tools to fix properly so will have to wait for another day
Spookily, the bulb in mine has actually died today and will be replaced later.
ThomasBellamy
A butane powered portable soldering iron set and a box of assorted heat shrink wrap is already in the post! I have to get cracking with this and the red/black door mod too as my central locking is knackered!darkchild wrote:Very, very common on slushmatic E30s. Time to get busy with the soldering iron! I've had to fix mine a couple of times.ThomasBellamy wrote:As darkchild suspected... popped the cover off and the wire had completely snapped off. didn't have the tools to fix properly so will have to wait for another day
No good soldering the wire to repair it. The constant flexing has changed the crystalline structure of the copper in the wires, which can only be reversed by heating to cherry red and cooling slowly - difficult with PVC insulated wires.
The whole length of wire, complete with bulb holder should be replaced, or it will fail again in a short time.
