M3 Offset Control Arm Bush Question
baggimodo
Post Fri Apr 12, 2013 9:41 am
Chaps,
got a pair of these from Magpie, and was just wondering if there needed to be anything else adjusted once these have been fitted?
Sorry if I'm being dense here, had a look through the wiki, and there's no mention of it, but i wanted to be sure before I tackled it :)
ross_jsy
Post Fri Apr 12, 2013 9:43 am
Nope, just fit them into the "lollipop" bushes, press them onto the end of the A arm and bolt up to the car
harry_p
Post Fri Apr 12, 2013 9:45 am
In an ideal world you'd get the tracking checked, as by moving the rear of the wishbone the whole arm is swung a little so the outer balljoint will sit slightly further forwards and slightly closer in to the car, so you might end up with a fraction more toe out.
any change is likely to be pretty small though.
cheers,
harry
**BANNED**
As always with front suspension/steering work,checking front wheel alignment is a good :idea:
I use one of those drive over 'Trackrite' gadgets.
Youth is wasted on the young.
baggimodo
Post Fri Apr 12, 2013 9:57 am
Quick replies!
That's what I was thinking, as by moving the mounting position of the rear of the wishbone would move everything round a couple of degrees (as i understand it)
No reason not to get cracking then! :D
