power steering fluid
frenchi
can some one tell me how much power steering fluid is in the system so i can buy the right amount also is there a certain type to go in,many thanks
j2b
Get a 1L bottle more than enough, automatic transmission fluid (ATF) dextron 3 now i believe.
89 more door 6 pot
If you're changing the fluid, you'll need to flush it a couple of times to do the job properly, so you might need a bit more than 1 litre.
