Hi all, I've read on here and elsewhere stories about things coming loose inside the lower sump on M40 engines and as I'm about to service mine I thought it could be an idea to whip the sump off and check all is ok. So two things,
1. I this worthwhile doing?
2. Is the gasket a BMW only item?
Cheers.
M40 lower sump removal and refitting
Grrrmachine
- E30 Zone Wiki / Team Member
1. Depends whether you want to risk total engine failure or not
2. A number of companies manufacture gaskets on behalf of BMW
Read this:
http://www.e30zone.net/e30zonewiki/inde ... Sump_Bolts
Read this:
stew72
Thanks. I assume this is applicable to the M40 too?
I've tried GSF for the sump pan gasket and they don't stock, I'll try ECP tomorrow.
Billwill
stew72 wrote:Thanks. I assume this is applicable to the M40 too?
The M40 sump cover is in two parts (on the E30 M40)...the lower one is easy to remove and put back. I have done it and used the original gasket with RTV silicone sealer and have no leaks....best to get a new gasket though.
The upper sump cover is impossible to remove as the cross member is in the way.
