my car run everywhere if the front tire hit small hole, bad
markus_74
Post Thu Apr 04, 2013 12:21 am
hello, need help and opinion
my car will go everywhere if front tire hit small hole, bad surface road, etc i feel the tire lost contact with the road and then goes everywhere, it is more worst if i raise the speed.
I have check ball joint etc but need second opinion from zoner here, what I need to check and replace?
I use m3 rear bushing since 4 years ago, good on straight run but huge body roll if I turn.
thank you
markus
Post Thu Apr 04, 2013 9:57 am
Dampers?
pnd
Post Thu Apr 04, 2013 10:23 am
wheel size? alignment?
BenHar
Post Thu Apr 04, 2013 12:01 pm
Steering column rubber donut?
Ben
markus_74
Post Thu Apr 04, 2013 3:43 pm
Brianmoooore wrote:Dampers?
hello, you mean shock absorber? it is in good condition
markus_74
Post Thu Apr 04, 2013 3:44 pm
BenHar wrote:Steering column rubber donut?
Ben
steering column rubber donut is new one
markus_74
Post Thu Apr 04, 2013 3:46 pm
pnd wrote:wheel size? alignment?
my wheel is 14" I have make alignment also, only when I hit hole it suddently goes everywhere
gromgsxr
Post Thu Apr 04, 2013 5:23 pm
Lower arm ball joints and rear bushes on lower arms my car was all over the place changed lower arms and bushes was a lot better after that. May be a I dear to get the front of the car off the floor and have a peak around at all the moving bits underneath the car.
capnmchl
Post Thu Apr 04, 2013 10:48 pm
Check these, but before hand, I'd check the tyre pressures and the tracking.
After that it's a case of checking all the ball joints, bushes and dampers for excessive wear/play.
