Having been converting the rear of my car from cheese brakes to disk iv obviously had to have the drive shafts out, but the way its worked out is iv only had the drive shaft completely off of one of the hubs where its not been connected to anything else. There is slight play in the hub and im wondering is this wobble normal or is the bearing goosed?
Because magpie couldnt get the other drive shaft out the other side iv just put it straight on so theres no wobble....does the wobble go away when the driftshafts are connected up etc. Or do I need a new hub bearing?
Play in rear hub, is this normal?
verde
Raise hell praise Dale.
