whats the going price for m20b25 engine,manual box and ecu?
danxs
Post Sat Mar 30, 2013 12:57 pm
hi there, whats the going price for my e30 cab engine and box for someone as a swap
m20b25 ecu complete with manifolds, ecu, manual box with no crunches?
im stripping it out of my e30 ready for my new engine swap, i think i need to keep the loom but im not really sure. il include it if i have to lol
its on 150 odd k but has loads of history and in the last 4 years has only done 5k with regular servicing. it doesnt use oil or water or smoke
any ideas?
matt86
Post Sat Mar 30, 2013 1:00 pm
Roughly 300, I would say. I paid 400 for the lot mileage on my engine was 85k. Engine, ecu, wiring loom, prop, diff, gearbox, shocks etc.
danxs
Post Sat Mar 30, 2013 1:07 pm
ah ok, im keeping my 3.64 lsd and need the rear half of the prop. possibly need the loom but not really sure till i get busy chopping lol
might make a for sale thread then and see
cheers!
jmc330i
Post Sat Mar 30, 2013 1:37 pm
What engine is going back in?
Ideally any engine you're fitting should be complete with loom, then it's just a case altering the loom to match the E30s wiring at the plug near the bulkhead (c101 plug from memory).
You shouldn't need to chop any of your M20 engine loom. It just unplugs from the car side of the loom (c101 plug) and stays attached to the engine when you pull it out.
James
'91 325i Sport
'93 318i touring 16v
danxs
Post Sat Mar 30, 2013 1:45 pm
I'm not sure, I was planning on wiring the BMW plug into the Nissan loom and plugging it in etc....
Sr20det
jmc330i wrote:What engine is going back in?
No one's going to want half a prop. either. They are balanced as a whole, and can't be mixed and matched without a full rebalance.
The only thing you will need from your existing loom is the twenty pin C101 plug, complete with about 300mm of wire. Pity to devalue your engine for the sake of a plug that can be taken from any loom from an unloved M40.
danxs
Post Sat Mar 30, 2013 1:46 pm
Guess its worth more with the loom. Much more than 300 as a straight engine, box, loom and ecu swap?
Andyboy
Alpina Colada
Post Sat Mar 30, 2013 3:53 pm
I would say £375+ if it's a real peach, is dry and can be heard running. As an oily lump sat on the floor, they aren't worth as much.
danxs
Post Sat Mar 30, 2013 4:49 pm
well its still in the car, quite clean, uses no oil or water and no crunches from the box
