capnmchl
Post
Wed Mar 27, 2013 11:48 pm
Turns out I'm not too bad at it either.
This is my 3rd attempt
Should be handy for when the inevitable rust fest strikes my so far relatively unrusty chromie
Also stripped down my old auto gearbox as part of a uni assignment. It's spotless in there. For something that's 26 years old and done 80k miles, and never had an oil change, you wouldn't know it
Post
Wed Mar 27, 2013 11:50 pm
Congratulations! It's definitely handy to know you can weld, as it relieves some of the stress come MOT time.
capnmchl
Post
Wed Mar 27, 2013 11:53 pm
Cheers man. Don't think I can bring myself to let the lance near my car (not in my hands anyway), but I'll keep on practicing and practice makes perfect ;)
Post
Wed Mar 27, 2013 11:57 pm
Indeed, after a few trial runs (I practiced on an old Mini bonnet for my first efforts), you'll soon be well away.
harry_p
Post
Thu Mar 28, 2013 12:02 am
now try it on some metal you've had to touch with a grinder to remove the paint, and upside down
cheers,
harry
Post
Thu Mar 28, 2013 12:07 am
harry_p wrote:now try it on some metal you've had to touch with a grinder to remove the paint, and upside down
in a tight space with your hair on fire and sparks going down your sleeve
snakebrain
Post
Thu Mar 28, 2013 12:59 am
capnmchl wrote:Also stripped down my old auto gearbox as part of a uni assignment. It's spotless in there. For something that's 26 years old and done 80k miles, and never had an oil change, you wouldn't know it
Now let's see you put that back together!
capnmchl
Post
Thu Mar 28, 2013 7:16 am
Haha, I understand it'll be harder upside down with my head wedged between the sill and the floor.
That auto box is never going back together. I knew that 10 minutes in when a load of plastic ball bearings fell out and went everywhere!
- **BANNED**
Post
Thu Mar 28, 2013 8:23 am
Odd how youngsters are good at pulling things to bits,but crap at putting 'em back together....
I remember pulling my dad's pocket watch to bits as a child...
My lad just 'Wanted to learn how the video recorder worked'....
Jos
Post
Thu Mar 28, 2013 2:52 pm
e30topless wrote:harry_p wrote:now try it on some metal you've had to touch with a grinder to remove the paint, and upside down
and those lovely blisters on the outside of your left upper arm that scar like hell
Overhead root run stick welding for ultimate bodyfire
'94 e36 tree climber
Post
Thu Mar 28, 2013 3:14 pm
And the funny dance you do when some molten weld melts its way through your trainers.
Jos
Post
Thu Mar 28, 2013 3:31 pm
Speedtouch wrote:And the funny dance you do when some molten weld melts its way through your trainers.
Yeah! leather boots all the way; although don't wear steel toecaps when welding since my father regaled me with an story from the ships involving some molten metal down the inside of a steel boot that couldn't get out...
Jozi
Post
Thu Mar 28, 2013 5:50 pm
I've had that! Welding gloves help a lot but I've still got plenty of splatter down my neck or burn through clothes.
Jesus325iTouring
- Frog freak !
Post
Thu Mar 28, 2013 6:30 pm
And in your ear
I need to learn to weld properly,my welding is rubbish and the gaping holes in my sills keep telling me to not stuff them full of p40 and news paper
- **BANNED**
Post
Fri Mar 29, 2013 1:46 am
Jesus325iTouring wrote:e30topless wrote:harry_p wrote:now try it on some metal you've had to touch with a grinder to remove the paint, and upside down
And in your ear
Not so sure on that Roger,page 3 usually displays plenty of silicone...
Jesus325iTouring
- Frog freak !
Post
Fri Mar 29, 2013 2:20 am
Silicone sills FTW
G-Bear
Post
Sat Mar 30, 2013 10:43 pm
I had that working as a labourer when I was about 17.. Only it was molten from an engineering block I was cutting. Watched it burn through my trainer with amazement, unbeknown of what might happen next.
Post
Sat Mar 30, 2013 10:56 pm
Yeah, red hot steel burning its way into into your feet makes you move a bit sharpish!
kam-325i
Post
Sat Mar 30, 2013 11:36 pm
Jos wrote:Overhead root run stick welding for ultimate bodyfire
Been there, Done that !!!!
Ill drag the TiG set out for the car now.
G-Bear
Post
Sun Mar 31, 2013 9:50 am
I've only welded on a bench.. Looking forward go the day of trying to fit my head, helmet and weld nozzle into a wheel arch..
lhd220turbo
Post
Sun Mar 31, 2013 11:23 am
good effort & naturally you'll get better as you do more
i will say tho, that welding new metal is very easy, its trying to weld shit old thin metal to new metal is the art!
