.....put an E36 M3 donkey in an E30 but run it on throttle bodies or maybe even carbs ?
If so what were the results ?
Just wondered that's all
Has Anyone Ever.....
ross_jsy
You are aware s50's run on throttle bodies already right...
So yes, many have
So yes, many have
Darren325is
Sorry, I meant an after market kit as in proper trumpets
harry_p
e36 m3s run on throttlebodies as standard, so every s50 converted e30 runs on them
It would only take an alpha n remap to be able to remove the maf and airbox and run them as open trumpets, which would sound absurd, but lose power compared to a carbon airbox, or possibly even the standard setup as they'd be pulling in hot air all the time.
cheers,
harry
harry
Darren325is
ross_jsy
They are proper trumpets.
Do you mean something like a carbon airbox? If so yes people have fitted them, but there are clearance issues with the servo
Darren325is
I meant something more like this where the trumpets are open
ross_jsy
A zoners e21:
http://www.e30zone.net/modules.php?name ... c&start=25
But that's a packaging issue rather than a performance modification
harry_p
like i say, get the ecu modified and you can run without the maf, and bung whatever trumpet you like on the end of the throttles
http://www.youtube.com/watch?v=bs37FMSDNoM
cheers,
harry
harry
