e36 m44 into e30
bmartin
helping a mate with a M44 into e30. He only has the M44 engine mount outrigger brackets. Can we juggle engine mounts ie rotate the offset mounts to fit?
louie_corse
I would like to see a complete report on how to do the swap from M40 to M44b19
If you can send some info/links/whatever, i´d appreciate
Louie_corse from PT
BMW 318i M40 1987 - The Diplomat
jmc330i
You will need E30 M42 engine mounts, the M44 mounts hit the inside of the chassis no matter how you rotate them.
You can use the M40 mounts with hydraulic damper, but the vibrations are worse than with the M42 mounts.
I have a complete M44 running in my touring, rather than the usual M44 with M42 intake and wiring.
I do have a build thread of mine, but I've not updated it in well over a year - the car with M44 has been in daily use since May 2014.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
