Got some new bearings from meatballs ecp chap on here.
Whacked them on, but I don't remember being able to see the bearings themselves with the old assembly.
What do you think?
Pete.
I bought brand new bearings from from GSF, and the hub nuts were the wrong size, had to use the old onesuedenim wrote:did you even get a new hub nut in the kit? looks like you've used the old one with the facory paint mark showing in a different position... does the other side have dust cover?
I bought one from GSF out of desperation, it broke during fitting, never again!Chris_B86 wrote:I bought brand new bearings from from GSF, and the hub nuts were the wrong size, had to use the old onesuedenim wrote:did you even get a new hub nut in the kit? looks like you've used the old one with the facory paint mark showing in a different position... does the other side have dust cover?
