New to the E30 world - have a few questions!
AlfieN
Post Mon Mar 04, 2013 9:46 pm
hello
i have recently purchased a 325 touring in good spec, but im new to E30s.
it has an LSD fitted, but needs reconditioning as i am not happy with it. it seems to skip quite a lot when manouvering, although it is definately not a welded diff as i used to own a Volvo with one and know what they feel like.
how would i go about finding somebdy to recon it, and would anybody know a rough price/timescale estimate?
cheers,
Alfie
Sex should be like drifting...
Fast, dangerous, and loud enough that neighbours complain!
DHFiS
Post Mon Mar 04, 2013 9:52 pm
AlfieN
Post Mon Mar 04, 2013 10:01 pm
i have PM'd him.
many thanks
Post Mon Mar 04, 2013 10:18 pm
are you sure it not just a welded diff,what checks have you made ? you would get clutch slip from an lsd no ....
polsta
Post Tue Mar 05, 2013 4:28 pm
are you sure its an lsd ie checked the tag on the diff ?
Chris_B86
Post Tue Mar 05, 2013 5:07 pm
Sure it's not got an expensive 2 way in there? Had a Kaz 2 way LSD in my R32, and that used to skip and clunk as it was trying to lock up at slow speeds on tight turns
1990 E30 325i Sport Sterling Silber
1999 E36 323i Sport Touring Techno Violet
AlfieN
Post Tue Mar 05, 2013 7:29 pm
Suppose I should probably have a good look, where would I find the tag on the diff, and what should it say?
gooner1
Out humping Reindeer
Post Tue Mar 05, 2013 7:34 pm
Look for a tag on the back plate,undo the bolt it's held on by clean it it up and hope it starts with an 'S'.
AlfieN
Post Tue Mar 05, 2013 8:07 pm
Will it also say the ratio?
pony
Post Tue Mar 05, 2013 8:38 pm
Have u considered buyin a Quaife LSD had lifetime warranty ????
DHFiS
AlfieN wrote:Will it also say the ratio?
Yes. S = LSD and the numbers after that are the ratio. Bound to be so corroded you will struggle to read it.
pony
AlfieN
Post Thu Mar 07, 2013 9:33 am
Not really in the position to buy a Quaife financially at the moment...
Chris_B86
Post Thu Mar 07, 2013 9:35 am
pony wrote:Have u considered buyin a Quaife LSD had lifetime warranty ????
That's a bit extreme, probably half the value of the car
