Rear big brake kit
Sjoerd320i
Mon Feb 25, 2013 2:53 pm
I will be using a 330i front setup on my cab, so that will have 325mm front rotors with e46 330i callipers.
Now I'm looking for a suitable rear upgrade. I am running an e36 318ti rear axle so it's allready 5 stud. I remember having read somewhere on the net that 120d rear discs are suitable for the ti rear axle maintaining the original handbrake. Only thing is, what callipers to use with those discs.
Anyone who has done this upgrade?
Tia!
Jimbob
Mon Feb 25, 2013 7:40 pm
I think davethegoat has those rear discs, would be worth checking his build thread.
ajay
Mon Feb 25, 2013 8:41 pm
As above, Dave has done this: but its a very technical exercise, not a straight bolt on affair i do belive.
HairyScreech
Tue Feb 26, 2013 3:14 am
I assume e90 330i?
As e46 330i is the same 300mm disc as the 325/238 but with a bigger caliper that requires 17" wheels.
Sjoerd320i
Tue Feb 26, 2013 7:50 am
Thanks, I will have a look in his topic.
No I mean e46, the discs are 325 mm :wink:
http://bmwfans.info/parts/catalog/E46/C ... rake_disc/
harry_p
Tue Feb 26, 2013 9:52 am
do e36 m3 disks fit? not sure how big they are, but they look pretty large to me and i'm sure the rest of the handbrake mech (shoes, springs, clasp and adjuster ) are the same as the rest of the e36 range.
just looked on real oem, m3 rear disk is 312mm x 20mm (vented) 318ti rear disk is 272mm x 10mm (solid)
cheers,
harry
harry_p
Tue Feb 26, 2013 9:55 am
another post, z3m which uses compact based rear suspension uses the same rear disk as all e36 m3s
cheers,
harry
HairyScreech
Tue Feb 26, 2013 10:08 am
yes, z3m should be a direct upgrade but very hard to get hold of.
is there more than one variant for the e46 330i disc? as i have one downstairs that is 100% 300mm and was taken from a 330?
harry_p
Tue Feb 26, 2013 10:19 am
realoem shows the same 325 / 25mm front disk for all e46 330i, and the 325i saloon too.
cheers,
harry
ajay
Tue Feb 26, 2013 12:07 pm
I gave Dave a pair of Z3m rear disc,s he was interested in trying but for some reason he has not used them on his car. Worth a pm to see if he had any issues before getting a set.
Sjoerd320i
Wed Feb 27, 2013 10:11 am
The funny thing is the discs of the z3m and e36 m3 are the same as are the carriers, but the callipers are different. Sourcing the discs won't be a problem, neither will the carriers but the callipers might be an issue.
Demlotcrew
Wed Feb 27, 2013 5:00 pm
Dont the Z3M disks have a deeper bell to accommodate the extra 10mm wider track?
harry_p
Thu Feb 28, 2013 1:51 am
Shame my compact only has drums otherwise I would have bunged a disk off the m3 on to see how it fitted.
They don't seem particularly wide though, I assumed the z3ms track width was purely down to the wide low offset rear wheels, 9in et8 vs et41 for the usual 7.5in e36 wheels.
cheers,
harry
