Balancing a prop shaft?
Cloggy Saint
Silverfang
If it's not been dismantled, mark it prior removal.
If it has been dismantled, give it a good clean and make sure there's no sign of marks.
After that, It'd be time to find a local specialist.
BMW and Opel, both RWD, both german, both good fun
http://www.clockservicing.co.uk/ For any clock repairs try here.
maggspower
- Turbo Farmer Tractor Driver
Have another look for the dots, they are factory marked so may be under some grime. I have never failed to find them.
Failing that the prop should only go together 2 ways with the yolks of the universal joints at right angles to each other. So you have a 50/50 chance of getting it right
HTH
HTH
