Door question :-)
SEBRINGGREY325I
Post Thu Feb 21, 2013 12:10 pm
Are the doors from a sport the same as a standard se door , meaning the sport has the cladding bit once that's removed can it be used on an se spec car ?
**BANNED**
Post Thu Feb 21, 2013 12:24 pm
Yes,you should find that the body kit pod mounts using the same holes as the trim strip on proper E30's....do remember,though,that doors vary in length between 2 door and proper door cars!
Youth is wasted on the young.
SEBRINGGREY325I
Post Thu Feb 21, 2013 12:47 pm
Sorted its a coupe door that I am after .
Thanks .
