air box
trackpig
Post Thu Dec 01, 2005 10:03 pm
does anyone know what the funnel shaped part is in the air box of a E30 325 air box. it can be unbolted and i wondered what difference removing it may make
going to fit a k and n panel filter with a viper2 chip.
thanks
Templ8e30
Post Thu Dec 01, 2005 10:42 pm
It's a rampipe for the intake and helps bottom end torque.
I experimented with mine and found a slight loss of performance without it. I thought it looked too close to the airbox wall for good airflow but it does work.
I've ended up with the standard airbox/rampipe and a K&N panel filter after trying all sorts of different combinations.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
trackpig
Post Thu Dec 01, 2005 10:50 pm
thanks alot mr T
saved me alot of messing about.
Ziggy
Post Thu Dec 01, 2005 11:35 pm
Just converted back to the proper airbox, from a $hitty K&N cone... Haven't got that bit though so I'll be down the scrappies soon I expect!
