Cat or not
ConvertChris
Thu Feb 14, 2013 8:46 pm
hi, i have a 318i 1991 cab, it runs a cat, if removed will it make much difference!! I need to change the exhaust as it is blowing quite bad, not sure how much it is going to cost me! any one know where in the Chelmsford. Essex area where i can get it changed and won't get ripped off!!
Thu Feb 14, 2013 11:41 pm
See my post in this thread: http://www.e30zone.net/modules.php?name ... c&t=233439
The main difference you should see by ditching the cat. is a noticeable decrease in fuel consumption, as long as you fit a decent quality exhaust rather than the tat offered by the likes of Kwikfit.
Cloggy Saint
Thu Feb 14, 2013 11:47 pm
What if you ditch the cat and lambda on an M20?
Fri Feb 15, 2013 12:07 am
As long as you have a working CO adjuster on the AFM, no other changes needed.
BATTS91
Fri Feb 15, 2013 12:56 am
For used parts you could allways nip up to Richard at BBB , he could also fit for you too if needs be . About an hour tops up the a12 near ipswich .
Pm me if you want number ect
