rear axel bush problem.
makman
Ive got some poly buahes for my rear beam and there different where they mount...they have like a 25mm high section where they bolt into the chassos yet the chassis dpsent have room to accomodate it...theyblooks to be lile washers insude the chassis, one with splines to grip the main bolt then one underneath..if this comes out il be able to bolt it all up..my question is.can this be drilled or pressed out? Thanks, sprry fpr the bad spelling too..im using my phone outside and im in icecube mode aha
Canny Beat a chromie!'
Black_Op_88
I drilled mine out. Its a real dog of a job, lots of burnt rubber and you end up using the drill as a spoon stirring the old bush into bits before it can be pulled out.
Getting a new poly-bush in is an easier job though. Good luck. If you run into bother take some photos and get them up if you haven't already sorted it.
makman
In the end i managed to chissel the snapped bit of the old bush out and then i measured how much gap there was..then cut the new bushes down to fit. Tbh it fits perfectly haha i didnt think it would though!
