Bit of a wierd one, which happened before then sorted itself out, but back again. The car is off road and I only fire it up occasionally, but will have to put an MOT on it soon.
Indicators work as normal, but when you put the headlights on step one, the left indicator flashes very slowly, the right not at all. Headlights on step two and the indicators don't work at all, and the green bulbs are lit up as are the headlight bulb.
Any ideas?
Indicators work until headlights are turned on..wierd?!
milescook
Also please help the race budget by watching some videos
https://www.youtube.com/cookracinguk
Especially the ones behind the LH headlamp.willnz wrote:Check ground points esp one just behind the lhs headlight and behind the glove box.
milescook
Thanks that makes sense as ive been playing with both those areas.will look this weekend
Edit: yep it was the earth behind the lh light not secure.cheers guys! Not time soon...
