jacking problem
DazzyA
Post Wed Nov 30, 2005 2:04 am
Car is too low to get factory jack under so bought a cheap trolley jack and guess what, still to big, i have 100mm clearance to the jack points any help?? :cry:
Pass me the spanner
kam-325i
Post Wed Nov 30, 2005 2:07 am
I had the same problem with mine !!!! To get the jack under i had lift the car up while i got the misses to place the jack......
DazzyA
Post Wed Nov 30, 2005 2:09 am
ah, or get the missus to lift, nice one, i did borrow some ramps but nearly pulled the spolier off DOH.
:oops:
Pass me the spanner
ian332isport
Post Wed Nov 30, 2005 3:37 am
Just get a couple of pieces of wood and drive onto those first. This should lift the car enough to get the jack under.
I can't jack mine on the front subframe, as the sumpguard gets in the way. I can get a jack on the front chassis rails (under the front foot wells) though. I have two jacks and lift each side a little at a time until I can get the axle stands under.
Ian.
jordano
Post Wed Nov 30, 2005 10:39 am
same thing on my cab, i use one jack to lift the car slightly on a little bit that sticks out on the sill near the jacking point and this gives me enough room to get another jack onto the jacking point
worrying is like a rocking chair, it gives you something to do but it never really gets you anywhere
