3k RPM Limit
StuBeeDoo
Post Thu Jan 24, 2013 9:19 am
My M20 has develpoed a 3k(ish) rev limit under load. At the same time as this happens, the rev counter needle and econometer needle jump all over their respective guages.
I'm thinking TPS. Any other suggestions??
TIA
Stuart.
abelai
Post Fri Jan 25, 2013 12:43 pm
Check your DME relay I have heard this can cause some crazy faults under high electrical loads
If I can't fix it I'll f**k it up so bad nobody can!!
