dead locked car wont open
xedan
Post Tue Jan 22, 2013 4:26 pm
i brought a 2.5 touring last week the car had been sat for 6 months with a flat battery the car was dead locked ive opened the car with the key but only the drivers door unlocked and the rest is dead locked so i cannot open it even from the inside im not sure whats wrong anyone got any ideas
Post Tue Jan 22, 2013 4:44 pm
is the battery charged up yet ?
Captain_Birdseye
Post Tue Jan 22, 2013 4:56 pm
charge it up and fiddle around a bit. If the keyhole feels really stiff on the driver's side put some wd40 in the keyhole and catch and leave overnight, try again in the morning.
xedan
Post Tue Jan 22, 2013 5:37 pm
ive fitted a brand new battery and ive had a bit of a fiddle but still nothing i will try wd40 and see how i get on
Post Tue Jan 22, 2013 5:43 pm
try opening the boot with the key ,it sounds like the central locking is on the blink.
can you hear any motors moving from drivers door or the boot lid ?
Post Tue Jan 22, 2013 7:17 pm
willnz wrote:
You can try to open the front/rear manually by appying a 12v supply briefly to the green/blue and green/black wires from the C/L unit.
Earthing/grounding the green/blue and green/black briefly on an E30, Will. It's later BMW stuff that needs a 12 volt + pulse.
When you get the locking ECU out, the first test I'd do is to unplug it, and connect a 12 volt bulb of at least 21W (indicator or brake light bulb) between the red/black and brown wires.
If it lights at full brightness, then the red/black wire mod. is unlikely to help, although it should be done anyway for long term reliability. If it doesn't light, then check fuse 27 and do the mod.
