engine stall
Guest
Post Tue Nov 29, 2005 6:30 pm
Hi guys ,ive got bit of a problem with my e30 320i ,this only happens when i've just started it up. I will be doing 30 mph in second gear and the revs will just drop and the engine will stall ,then i start her back up and start of again and it will pop and splutter then clear then stall , once she is warm then it will not do it ,its only just started doing this since the weather has been getting worse ,now i replaced the disy cap and rotor last year ,i have had it chipped ,fuel boost valve and an eco valve and green filter ,but i am baffled on what the problem could be ,any ideas guys ?
please help as it is very frustrating
TOURINGDADDY
Post Tue Nov 29, 2005 6:31 pm
try the dme relay mate i did loads of head banging to find out it was a 7 quid relay! :oops:
JOSEMI
Post Tue Nov 29, 2005 6:35 pm
TOURINGDADDY wrote:try the dme relay mate i did loads of head banging to find out it was a 7 quid relay! :oops:
I have the same problem with my engine stalling... is the dme relay the one with two pins and covered in a rubber cone ???
Jose
TOURINGDADDY
Post Tue Nov 29, 2005 6:38 pm
dme relay is the white one on the passanger side inner wing under a black cover behind the abs unit
JOSEMI
Post Tue Nov 29, 2005 6:40 pm
got it thanks mate will have a look tomorrow morning
Jose
