clutch placement
Cloggy Saint
Post Fri Jan 18, 2013 7:16 pm
Can someone tell me which side of the clutch goes against the fly wheel, flush or with potrusion? :o:
HairyScreech
Post Fri Jan 18, 2013 8:20 pm
Most friction plates are marked and it could be either way depending on manufacturer and fitment.
However going out on a limb and assuming an m20 it tends to be flush to the flywheel and protrusion into the clutch cover, which is pretty much the norm on all stuff.
Post Fri Jan 18, 2013 8:23 pm
+1 /\ 8)
Cloggy Saint
Post Fri Jan 18, 2013 8:36 pm
Thanks, I should've taken more notice when removing it, lesson learned.
For the record, it's Sachs.
HairyScreech
Post Fri Jan 18, 2013 8:41 pm
FWIW, not the kind of thing you think about until it is too late.
Still not something your likely to do twice.
Post Fri Jan 18, 2013 8:50 pm
If you offer it up you will see it will only work one way
