Pressed the brake pedal and not a single bit of light came from the back. Changed bulbs for some that shouldn't be knackered (brand new) and I get the same result, no light when braking and the check control tells me one (or all) have failed.
All the other rear lights work (fog, reverse, indicate, driving light) so I'm confused as to just why the brake ones aren't working.
I realise this means there is likely a break in the circuit somewhere but I'm thinking that you lot will know if there are any common failure areas.
Any ideas from you knowledgeable folk?
