HT lead qustion. (message for Brianmooore)
ah
Post Sat Jan 05, 2013 4:24 pm
On a m20 OEM set of leads,where the HT lead goes into the rubber socket at the plug end,there is a metal socket that the lead attaches to.On my no.4 cylinder the lead fell out and a load of green crap came out.My question is,should there be a threaded pin on the of the metal socket to hold the lead in,if so mine has corroded away.I hope I'm making some sort sense.Part number-5
http://realoem.com/bmw/showparts.do?mod ... g=12&fg=05
Post Sun Jan 06, 2013 10:30 pm
End of the wire should be a short tube with a spring wire across it that slides over the threads of the plug. Pushes straight on rather than screws.
If you have green gunge in there something unusual has happened to your lead, and a replacement is due. Very unusual for an E30 ignition lead to fail, so second hand will be OK.
ah
Post Mon Jan 07, 2013 5:09 pm
Thanks Brian,but I maybe didnt explain it properly,I ment where the HT lead goes into the rubber HT cap at the other side,shown on the BMWOEM web site in my thread part number 12121705656
FinalD
Post Mon Jan 07, 2013 10:06 pm
Green crap sounds like copper rust/degrading maybe? How old is the dizzy cap?
I take it you mean the 'green gunk' came out from the dizzy cap end of the HT lead.
