Interior lights staying on?
hennabm
Wed Jan 02, 2013 5:18 pm
Well my 320 greeted me this new year with electrical gremlins. Pehaps it's protesting after been chucked out from underneath the carport :mad:
Anyway the lamps work as normal when the ignition is off on all doors.
When you get in and close the door/s the interior lamps work ok as well.
The problem comes when you open any door again after the ignition is on. The interior lamps won't go off again at all unless physically turned off on each lamp. :? :? :? :? or the ignition is switched off.
My first thought is an earth problem but where???
Any help appreciated please.
TIA
'82 323i henna
'10 116d Sport Red - MkI
'11 X3 3.0d SE
'89 240 DL Estate
Wed Jan 02, 2013 5:23 pm
Do you have the optional interior light delay module fitted? This is located behind the driver's side kick/speaker panel. If the relay is sticking, this would cause the problem you mention.
Also probably worth spraying WD40 in the door switches, as they may be sticking.
hennabm
Wed Jan 02, 2013 5:31 pm
Hi Speedtouch
No the vehicle is not fitted with the light delay and the switches all seem to work OK when tested.
I will try WD behind each one.
'82 323i henna
'11 X3 3.0d SE
'89 240 DL Estate
bigwinn
Wed Jan 02, 2013 5:50 pm
the only other one to check is the looms as they pass through the doors from the bulkhead, drivers door first
I had a similar issue and it was through an earth issue on wiring in door looms
Bronzit gone- she lives on
'89 325i auto touring: Malachite Green
Now, I'm no gynecologist, but I know a tw4t when I see one...
hennabm
Wed Jan 02, 2013 6:52 pm
Hi Bigwinn.
Cheers - will do.
'82 323i henna
'11 X3 3.0d SE
'89 240 DL Estate
Wed Jan 02, 2013 7:03 pm
If you don't have a delay module, I can't think of any possible conditions that would produce the symptoms you describe. There's absolutely no connection between the ignition switch and the interior lights in the standard wiring.
hennabm
Wed Jan 02, 2013 7:40 pm
Hi Brian
that was my initial thought - what could possibly cause the link and I drew a blank - hence my quest to seek advice from the experts.
'82 323i henna
'11 X3 3.0d SE
'89 240 DL Estate
Wed Jan 02, 2013 10:07 pm
Have you parked it next to the Fiat? In which case, it could be a bad case of Italian electrics syndrome, which is highly contagious! Or perhaps you were just hungover, and the lights appeared to stay on long after you had switched them off? :wink:
hennabm
Wed Jan 02, 2013 10:29 pm
^^^^^ :mad: :mad: :mad: :rolling: :rolling:
'82 323i henna
'11 X3 3.0d SE
'89 240 DL Estate
gooner1
Out humping Reindeer
Sat Jun 22, 2013 8:01 pm
Did you ever sort this, Mike?
**BANNED**
Sat Jun 22, 2013 8:44 pm
gooner1 wrote:Did you ever sort this, Paul?
You is as bad as I,the OP is called Mike! :o:
gooner1
Sun Jun 23, 2013 10:25 am
Ta Malc. :thumb:
hennabm
Sun Jun 23, 2013 10:47 am
Thanks Fred et all
The problem went away all by itself. I never did sort out where the electrical gremlins were hidden. :mad: :mad:
The problem perisited about a month and all I did was make sure that I followed a procedure so as the lights were off.
Then I tried after a month and the problem was gone. :?
The only difference in conditions etc was that after a month it was back to living under a carport. Before that it had to spend its life parked open to the elements. Once back under the carport all problems disappeared. Maybe the damp got to it somewhere whilst outside.
'82 323i henna
'11 X3 3.0d SE
'89 240 DL Estate
gooner1
Sun Jun 23, 2013 11:08 am
Thanks Mike. I ask because of this http://www.e30zone.net/modules.php?name ... c&t=239527.
This is with the ignition off.
hennabm
Sun Jun 23, 2013 1:08 pm
It does sound a similar problem to mine. although mine worked perfectly with the iginition off. Therefore mine was only getting a feed when the ign was on.
having read your thread and the reply, have you tried putting some thick cardboard on the door where the switch strikes to see if it is just the door not touching the switch enough? Just use blutac or something like to hold the card long enough.
'82 323i henna
'11 X3 3.0d SE
'89 240 DL Estate
