Help Help Help e46 bonnet cable snapped cant open it grrrrr
dazleeds
old skool raver
old skool raver
Post Sun Dec 30, 2012 3:17 pm
classic e30 trait :( but this time on an e46
snapped at the handle as always
have looked at several e46 sites and theyre all retards who strip half the car to fix it,no way am i doing that
so anyone got a nice simple way of doingthis ??? can it be done like an e30???
i hope so :(
www.oldskoolfantasy.co.uk
skooshy
Post Sun Dec 30, 2012 4:03 pm
if your very carful remove the kidney grills and you can pull both sides of the cable from there .......
dazleeds
old skool raver
old skool raver
Post Sun Dec 30, 2012 4:06 pm
skooshy wrote:if your very carful remove the kidney grills and you can pull both sides of the cable from there .......
theres no little release hole like an e30 then??
cheers for answer tho :)
any other ways?? think i'd rather strip footwells than try get grilles out tho :(
sunnyr83
Post Sun Dec 30, 2012 4:15 pm
Had this happen in an e36 andopened via the method Skooshy has said, are they not similar?
Post Sun Dec 30, 2012 5:22 pm
What broke? The plastic handle or the cable itself?
dazleeds
old skool raver
old skool raver
Post Sun Dec 30, 2012 6:01 pm
cable where it joins to the handle
its a nasty thin cable :(
Post Sun Dec 30, 2012 6:19 pm
The round end part of the cable snapped off?
dazleeds
old skool raver
old skool raver
Post Mon Dec 31, 2012 12:21 pm
yeh spot on bas
looks like i'll be digging out the pliers till i can be bothered to change the cable :(
wish they had the hole in grille like an e30 would be far easier lol
Post Mon Dec 31, 2012 12:41 pm
The reason why thats snapped if because the cable is partially seized or the bonnet catches are. They are quite common for getting rusty and stuck.
I would be getting the problem sorted asap as using pliers will end up chewing the cable and then if there is nothing to grab it will make things a lot more awkward.
dazleeds
old skool raver
old skool raver
Post Mon Dec 31, 2012 12:48 pm
hmmmm will get it open asap and have a good look at it all,and lube it all up winkeye
nice one mate :)
maxfield
Post Mon Dec 31, 2012 12:56 pm
Not sure if its possible on an e46 but I once used a solderless nipple on a bonnet cable to put back into the release. That was on a corsa I was selling. They keep them in bike shops and are about 50p.
dazleeds
old skool raver
old skool raver
Post Mon Dec 31, 2012 1:00 pm
nice idea mate :)
sadly i dont think theres enough cable to get one on :(
