is LPG converson on 316i touring worth it?
cougar
Post Thu Dec 27, 2012 2:34 pm
or should get bigger engined e30?
current cars, 4 e30 tourings, 2 e30 cabs, 1 e36 328i sport, 1 e36 328i cab
cougar
Post Thu Dec 27, 2012 2:53 pm
diable wrote:With the amount of cars that you have which one do you use the most
only a few are runing lol :D
Nobby_N
Post Thu Dec 27, 2012 2:57 pm
I want pictures of your driveway :D Must take hours sweeping up every morning!
Post Thu Dec 27, 2012 9:25 pm
LPG conversion is worth it, if you do any quantity of miles. Question should be: is the 1.6 worth it, when a 1.8 is available for next to nothing, and fit-able in a day ?
cougar
Post Fri Dec 28, 2012 10:51 am
Brianmoooore wrote:LPG conversion is worth it, if you do any quantity of miles. Question should be: is the 1.6 worth it, when a 1.8 is available for next to nothing, and fit-able in a day ?
i do have 1.8 bottom end can i use 1.6 head or has to be everything from 1.8
mr_dink
Post Fri Dec 28, 2012 1:00 pm
1.8 bottom end and ecu, everything else is the same on 1.6 as far as I know.
Post Fri Dec 28, 2012 4:19 pm
mr_dink wrote:1.8 bottom end and ecu, everything else is the same on 1.6 as far as I know.
Except AFM.
e301988325i
Post Fri Dec 28, 2012 7:21 pm
cougar wrote:or should get bigger engined e30?
M20 b25 engine and a simple single point LPG install on that, job done.
I said:
e30topless said:
lock the wife in there
Post Fri Dec 28, 2012 10:51 pm
It's a touring, so has all the suspension and brake upgrades required for 325 power already fitted. Only harder front springs needed for the extra engine weight.
