Ignition Problems Still HELP !
m-dtech
Unapproved Trader caution
Post Sun Nov 27, 2005 8:28 pm
Ok so far;
Replaced. Rotor Arm, Dizzy Cap, HT Leads.
I have traced the -ve feed and all seems ok.
What voltage/current should i be getting at the +ve of the coil ?
Is there anything to do with the engine relays that could affect the +ve feed ?
Batter is fully charged.
HELP ! :cry:
fixedwheelnut
Post Mon Nov 28, 2005 2:39 pm
Should get between 10-12 volts at the coil depending on the type of coil it should be marked on it.
Check the DME relay that powers the ECU it will be the 5 pin white one.
