Fan switch wiring
kam325itouring
Post Wed Dec 12, 2012 3:51 pm
Can someone enlighten me on the wiring on a fan switch on a m52 conversion?
I have a e36 compact 3 pin fan switch and 5 pin relay. Just need a diagram or which pun to connect to on the fan switch I know ones a earth and the other two are high temp and low temp.
Help would be grateful.
All Car Audio - Approved Alarms - HID Kits - Custom Boot Installs - All jobs considered
Supafly
Post Wed Dec 12, 2012 6:53 pm
From what I can remember the switch should have markings on it to indicate which pins do what. I wired mine up properly through the fuse box after searching through some threads on here. Can't remember which threads but they were easy enough to find... if I get time later I'll see if I can find them and post em up.
Supafly
kevo
Post Wed Dec 12, 2012 9:44 pm
heres the link to the wiring diagram I made when I did mine.
cheers
Kev
kam325itouring
Post Fri Dec 14, 2012 6:37 pm
All done cheers peeps got a compact fan switch wired it to 80c running perfect.
