Guys im doing a m10 to m20 325i swap
Im using a late 325i g reg sport engine
Engine is in
Now stuck on the wiring
What is involved?
Also what about the fuel pump side of things?
Your help will be very much appreciated.
M10 to M20 swap(wiring)
SHAZ325iSPORT
capnmchl
316 or 318i?
SHAZ325iSPORT
Kedge
Is it a later 316 with a C101?
If so there are two wires you need to cut on the ECU plug and then connect to the C104 plug which will now be unconnected following the removal of the old loom. The easiest thing to do is cut the matching plug from the old loom and plug it into the loose plug in the car. Then you need to connect pin #1 (Blk/Blu) on the C104 to pin #6 (Blk) on the ECU, the second connection to make is to connect C104 pin #3 (Wht) to ECU pin #32 (Wht/Blk), C104 pin #2 is not used. This is purely for the instruments.
You need to fit the return fuel line then just use a later intank fuel pump, one with the return on the top like on a 318iS. Then find the unused fuel pump connection underneath the rear bench seat, extend them slightly so they will reach the intank pump and then fit the fuse in the fusebox.
JdmFanBoy
On the same swap what would cause the rev counter to stop working? It was working prior to the swap?
ANy help appreciated
Kedge
Kedge wrote:If so there are two wires you need to cut on the ECU plug and then connect to the C104 plug which will now be unconnected following the removal of the old loom. The easiest thing to do is cut the matching plug from the old loom and plug it into the loose plug in the car. Then you need to connect pin #1 (Blk/Blu) on the C104 to pin #6 (Blk) on the ECU, the second connection to make is to connect C104 pin #3 (Wht) to ECU pin #32 (Wht/Blk), C104 pin #2 is not used. This is purely for the instruments.
SHAZ325iSPORT
