As per title, I bought 16mm bore generic radiator pipe not realising that one end was a 16mm stub and the other stub was 20mm. I managed after much effort, hot water and chamfering the inside of the pipe with a blade to fit said pipe and it is holding.
What are people's opinions, will this last or do I need to fork out for the proper dealer supplied pipe?
Or is there a cheaper reliable solution other than the £50 dealer supplied pipe?[/quote]
Will stretching 16mm bore radiator pipe over 20mm last?
e301988325i
I said:
e30topless said:
lock the wife in there
Mikey_Boy
Doubtful - it will split eventually... What's the hose for??
steve_k
get the proper size pipe, at least you avoid the risk of it splitting on you mile's from anywhere.
HairyScreech
The cheaper (but a touch bodgy) option would be to go 20mm all the way with a bit of the 16mm over the small stub then clip both down tight.
Or a better solution, knock up a but of metal tube to reduce from 20-16mm while on your lunch break and fit it mid hose with an offcut of the origional 20mm tube.
Whats it for? the focus?
jmc330i
You can get hose connectors that step in sizes, I think I got mine from one of the motor factors in Taunton, I expect halfrauds also sell them.
I used one my on S50 conversion for the pipe from the header tank to the back of the head as the stubs are different sizes.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
e301988325i
this is the trouble of having a 5wk old baby, complete & utter loss of intelligence, thanks guys.
I said:
- **BANNED**
As excuses go,that must be up there among the best!e301988325i wrote:this is the trouble of having a 5wk old baby, complete & utter loss of intelligence, thanks guys.
Just hope the little 'un gets her looks and brains from her mum...
e301988325i
securd a suitable stub from halfrauds for a couple of quid. Just can't remember why now.jmc330i wrote:You can get hose connectors that step in sizes, I think I got mine from one of the motor factors in Taunton, I expect halfrauds also sell them.
I said:
e301988325i
As I asked in E30 tech help, yes I was Focusing on my E30 at the time.HairyScreech wrote:Whats it for? the focus?
I said:
Stretching hoses is usually ok up to a couple of mm, clamping hoses down as they are too large and they are doomed to fail, split around the jubilee clip is imminent.
HairyScreech
Hmmm. Very much so.e301988325i wrote:As I asked in E30 tech help, yes I was Focusing on my E30 at the time.HairyScreech wrote:Whats it for? the focus?
How's the kid? Keeping you up all night?
Will have some time off shortly, will have to swing down your way.
e301988325i
Not too bad at all, from what I hear it's the 2nd ones that cause the real trouble. She seems to take up all available brain power though. Be good to catch up, those pistons are currently lost with the courier FFS!HairyScreech wrote:Hmmm. Very much so.e301988325i wrote:As I asked in E30 tech help, yes I was Focusing on my E30 at the time.HairyScreech wrote:Whats it for? the focus?
Hose adaptor fitted, total spend being around £12 Vs £50 from the stealer.
I said:
