parking light constantly on due to changing the fuses
ameetgill1
Post Sun Dec 02, 2012 2:17 pm
guys i had the old wire fuses and decided to change them with the new blade ones.
now the right parking light does not got off and on the light rear light and boot light is constantly on
any ideas why???
Post Sun Dec 02, 2012 2:22 pm
Parking lights are probably on because you've turned them on with the indicator switch.
Boot light is a separate, common issue, which is usually solved by adjusting the catch properly.
ameetgill1
Post Sun Dec 02, 2012 2:26 pm
its hard to explain with out looking at it, when the car is turned off the front right parking light is constantly on and the rear light is on.
i disconnected the battery too and changed the fuses again still the same problem?
Post Sun Dec 02, 2012 2:28 pm
Brianmoooore wrote:because you've turned them on with the indicator switch.
