ARB?
J4CK05EE30
Post Tue Nov 27, 2012 3:47 pm
Been thinking of getting some anti-roll bars for my car, and come across a few different ones....
anyone here used any of the below and which are highly recommended....
eibach- £295
http://www.raceperformancemodified.com/ ... r-ARB-Kits
h&r- £340-250
http://www.raceperformancemodified.com/ ... ll-Bar-Kit
racing dynamics- app £320
http://www.racdyn-usa.com/Merchant2/mer ... .81.30.010
Suspension techniques - app £217- these do look abit complicated to put on
http://store.vacmotorsports.com/suspens ... p1385.aspx
heres the different specs ive found on wiki-
Eibach: Front: 20mm Rear: 16mm
Suspension Techniques: Front: 22mm Rear: 19mm
H&R (adjustable): Front: 22mm Rear: 18mm
Racing Dynamics Early Style (adjustable): Front: 22mm Rear: 16mm
Racing Dynamics Late Style (adjustable): Front: 22mm Rear: 19mm
Duke137
Post Tue Nov 27, 2012 3:53 pm
Depends what you are trying to achieve I think. I have H&R adjustables on my Road car but all other suspension parts are new/replaced/upgraded to suit and the ride and handling are excellent.
Changing the ARB's goes hand-in-hand with renewing the whole lot in my opinion
There is a list of the options in the wiki
http://www.e30zone.net/e30zonewiki/inde ... i-Roll_Bar
Post Tue Nov 27, 2012 3:56 pm
There's a set of Eibach ones for £200 in the For sale section.
I too have a set of Adjustable H&R's
J4CK05EE30
Post Tue Nov 27, 2012 4:11 pm
im also looking to get new suspension, got another thread on here about that, and so far the b12 kit has been recommended...
tbh wanted to see if anyone on here has used the racing dynamics or the suspension techniques, and what they think of them....
Morat
Post Tue Nov 27, 2012 4:28 pm
I went with eibach rollbars thinking that they'd match the eibach springs in the B12 kit. I have no idea whether they are better or worse than HnR but they do the job for me :)
Grrrmachine
E30 Zone Wiki / Team Member
Post Tue Nov 27, 2012 4:35 pm
In terms of difference, just buy any of them, then take your car to a racing track, do about 500 laps until you know the course intimately, then replace the ARB for one that's 1mm thicker or thinner. See if it shaves 0.01 seconds off your lap time.
For all other intents and purposes, they're all as good as each other.
penton08
Post Tue Nov 27, 2012 4:49 pm
I had H&R roll bars on my old car, and racing dynamics ones on my current car. I honestly could not say if either where better than the other. The VAC ones do look like a nice bit of kit though!!
ajay
Post Tue Nov 27, 2012 5:15 pm
If your running wide/larger wheels than standard,beware the H&R bars are shapped different to standard bars (stick out on the corners) and can just foul the inside edge of your rim on full lock. Not sure if the others are the same.
Demlotcrew
Post Tue Nov 27, 2012 5:32 pm
Almost all after market front ARB's will touch the inside of the front wheels, I made a very simple lightweight and non destructive spacer which slips on the rack gear it self.
This is a 20mm spacer on a E46 rack, these can be produced for E30 and E36 racks.
With regards to which set? Well from the choices above it would have to be the H&R set, they have a tougher finish and the kit has a thicker rear bar.
Below is a comparison with a custom rear 24mm bar against a 18mm H&R that came off.
As a guide a 19mm ARB is 49% stiffer than the same ARB in 18mm and a 24mm ARB is 346% stiffer than an 18mm ARB. On a well configured car going from 18mm to 19mm is noticeable.
Andrew
ajay
Post Tue Nov 27, 2012 6:07 pm
I tried a 20mm rack spacer kit(46 rack fitted) but it seemed to affect the lock (car not running) so i cut the spacers in half to make them 10mm. At the moment they are off the car as i found that the edge of the tyre touches only when front of car is jacked up, on the ground it clears. No doubt ill find out if i need the 10mm spacers once it fires up and i get some power assisted steering.
Jimbob
Post Tue Nov 27, 2012 6:12 pm
Ireland Engineering do some hefty kits, but price gets a high when you consider import fees.
Demlotcrew
Post Tue Nov 27, 2012 6:15 pm
ajay wrote:I tried a 20mm rack spacer kit(46 rack fitted) but it seemed to affect the lock (car not running) so i cut the spacers in half to make them 10mm. At the moment they are off the car as i found that the edge of the tyre touches only when front of car is jacked up, on the ground it clears. No doubt ill find out if i need the 10mm spacers once it fires up and i get some power assisted steering.
Yes it does affect over all lock as you are effectively limiting the travel of the rack gear. The problem you may face is when the MOT tester is checking for clearance with the car jacked up, most will focus on this especially if they notice any witness marks on the ARB it self.
Post Tue Nov 27, 2012 6:29 pm
Ive had advisories before for the tyre touching ARB on full lock, depends how much of an arse the tester is at the end of the day
ajay
Post Tue Nov 27, 2012 6:47 pm
Maybe i can distra££ct him when it goes up for its test! LOL
Post Tue Nov 27, 2012 6:53 pm
A jubilee clip around the end of the rack makes a quick and easily installed lock stop!
Bristol_Jer
Post Tue Nov 27, 2012 7:24 pm
Anyone had experience of the Whiteline ARB's?
