EDIT: Will host pics soon
Looks sweet as!
Adam
Yeah but those drilled discs will crack if used hard/properlyrare wrote:Not really a fan of them wheels, but damn! Look at the brakes!!!
Care to explain why?Lordschleife wrote:Yeah but those drilled discs will crack if used hard/properlyrare wrote:Not really a fan of them wheels, but damn! Look at the brakes!!!
18Adam318i wrote:Ah poo, ok will host the pics myself and put them up tomorow night.
btw, this M3 is fooking gorgous, with mahoosive front brakes under the 18/19's.
Adam
Antera 349tbmw wrote:what wheels are they??
I think the drilling is to allow gases to escape, rather than cooling.318-is wrote:drilled discs crack under extreme heat because they are effectively weaker than normal vented ones. imagine driling through the disc in all those places; it weakens them alot, and under extreme heats as they expand, they crack a lot easier.
its common for drilled discs to crack on any performance car. i fail to see how if cools them more anyway?
lovely cailpers though!
That's what Brake Fade actually is. A build up of Gas between the pad and disc. People seem to think its the pads getting to hot and loosing adhesion, but the truth is they cant even get to the disc!Lordschleife wrote: I think the drilling is to allow gases to escape, rather than cooling.
If enough gas comes out of the pads under hard braking, it can form a 'cushion' between the pad and disc, reducing braking ability.
As you say not ALL drilled discs will crack. Thats why I pulled you up on it.Lordschleife wrote: The cracking of drilled discs is a well known problem, the only ones with any resistance to cracking I've heard of are the factory Porsche ones because the holes are actually cast in them, not drilled, and they have still been known to crack.
Much better off using grooved discs, as they're less likely to crack, still allow some gas escape through the grooves, and also the grooves can help prevent glazing of the pads
Agree, nice calipers!
It was in for the Brembo brakes H&R coilover was going to have CF air intake but would not fit had the strut brace sway bars and anti roll bars and new engine managment which isn't finished and also had those wheels put on. no i dont mind you posting picsAdam318i wrote:Hi maxfield, hope you didnt mind me posting the pics (well i didnt, someone beat me to it)
But it is a very nice car, what was it in the garage for, a RR session?
Adam
roughly 6 yearssmit325is wrote:Which my dad drove something like that. Very nice has he had it long?
